Shadowman007
Just would like to first say Hi to everyone on this forum this is my first post. My names Nadeem and am from Slough, UK. I thought I'd do a little Introduction in this section and since I need help for my new build as well I'd do the two together.
In the past I have built a system but really messed it up to be honest i don’t want to go into details but lets say it was a overkill on some parts in other words it was not a balanced system.
So know it’s been over a year since I had a PC desktop and am ready to build again. The build will mostly be used for gaming i will be doing some Photoshop and Video rendering not a lot but defiantly some. I would like to point out this build will be water cooled and I have the water cooling parts already since I have done custom water cooling setups for friends of mine in the past. My budget well it’s around about £4000 (yes that’s all that saving I have done for a year.
) but at the same time I don’t need a overkill build but at the same time it has to be kinda good enough to handle the latest games with ease and that to on the highest settings.
So I would really appreciate it if you could please advice me on the following.
PC Case:
Power Supply:
PC Monitor:
Motherboard:
CPU:
GPU Sli Or Crossfire:
Memory Ram (& how much):
SSD/HDD:
PC Case:
Power Supply:
PC Monitor:
Motherboard:
CPU:
SSD/HDD:
