Hello, and thank you for everything you guys do for people with questions, it's really appreciated. I finally registered on your forums after whoring it for weeks every day =) (Sorry, I'm lazy)
I would like some feedback before I buy these parts. Am I getting what I pay for or should I save on some parts? I'm not really looking to save money here, unless I'm buying an "overkill", but for once I'd like to have a good gaming rig that will max out the following games (BF3, Elder Scrolls V, SWTOR etc)
Yes - I will overclock, nothing insane to measure my e-peen, but perhaps a nice 4.5Ghz o/c should do. Please leave your feedback with a short explanation if possible.
My monitor is ASUS 24'' @ 1920 x 1080, and here are the parts that I am thinking about buying:
CASE ($79) CM Storm Enforcer - I really like the USB 3.0 motherboard connector, clean window, very user friendly inside, swap-able cages, cable management etc. (Sorry I hate the look of HAF series)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240
MOBO: ($179) (ASUS P8P67 PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0) As far as I know this is one of the best boards for my processor - fast & high quality, but feel free to prove me wrong.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703
CPU: ($219) i5 2500k. After a lot of research, people seem to recommend this processor for gaming over the 2600k because they are almost identical in performance, unless I want to use hyper threading for rendering etc. I don't do much of that, once in a blue moon I make a gaming video, and little PhotoShop here and there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
PSU: ($129) CORSAIR Enthusiast Series TX750M 750W. I would like a modular PSU. Is this a good choice? I am not sure if I will SLI - if 1 high end video card can max out games I will not mess with it. I will get probably the 570ti or something similar, will this PSU hold such cards in SLI? Or do you recommend another modular PSU in similar price range?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
RAM: ($57) G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
SSD for OS & couple games: ($114) Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC. This was recommended to me to install Win7 64 bit on + maybe one or two games. I will also buy a storage driver later, either the F3 spinpoint or WD Cabiar Black 1TB - haven't decided which is better yet but for now all I can afford is the SSD.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
Cooling: Corsair H80 ($91) After doing a lot of research, this performs nearly as well as H100. I do not want an enormous heatsink blocking view of my rig so I'm willing to spend $91 for this since it seems to perform as one of the best coolers around, but feel free to prove me wrong, please.
Grand total: $888.38 (For now I am going to have to use my 4870 HD 1GB but I will upgrade in a month, probably the 570 or something, as well as F3 Spinpoint 1TB or WD-Caviar Black 1TB.
Please leave your feedback and comments - they are greatly appreciated!
