[Needing help] Not filling screen in any resolution settings
BamDanUK
Hey Overclock3D users,
I got a new monitor today, running HDMI from my XFX 6850 graphics card.
Monitor/TV = Philips 23IT LED TV monitor
Not a graphics card or HDMI Problem, works fine using HDMI to my 42" LG TV.
Screen appears to be a little fuzzy + black borders all the way around my screen.
This is a pain and I need some help :S
If you have any ideas, Please leave them below of if you can help me add me on skype: BamDanUK
Thanks,
BamDanUK
Note: I've tried changing resolution.
Go to CCC, select MY Digital Flat Panels from the drop down list on the left and then click on Properties. There should be a box that you can tick that says Enable GPU Scaling, go ahead and mark that box.
Next select Scaling Options from the drop down list on the left. You will see a slider at the top on the right, you want to move it all the way to the right, that should make the picture fill the screen.
WOW!
Thanks for the fast reply, Sorted the not fitting the screen issue.
Still seems a little fuzzy with all the colours though.
It's normal with TVs, had to do the same thing with mine. Don't know what is causing the colours to be fuzzy on yours though.
Bring up the options on the tv using the remote/side buttons and look around for a pc mode, it makes a MASSIVE difference on my 42" toshiba, smooths the image + text out and helps with the colors a bit aswell.
Now I just feel dumb, there I was playing with every PC Setting possible!
Thanks man :)
Thanks to you both for helping me. Perfect now :)
