PHILIP1193
Which would you do???
Would you do.......
1. have two seperate 120.1's in loop each with a fan on sucking air through teh rad
OR
2. have 1 120.1 with a shroud either side using two fans in a push pull config?
Bearing in mind im going to be using cathars new block and obviously want teh best perfromance on it. People have said option 1 which im running now has a lot of flow restriction on it?
Phil
Would you do.......
OR
Phil
