Hello,
Yeah get straight to it I have installed my CPU i7 4930k went in fine no problem but Im trying to connect the H100i the back plate it comes with I tired to attach it you know behind motherboard the the holes dont go all the way through if you get me...
Because you put the back plate on then you screw in the screws the 2011's ones but I cant because there isnt a hole if you get me..... This is my first 2011 rig but its basically the same with like a 1155 or something isnt it ..?
The 4 corners where you put the back plate no hole :/
