DisturbedJim83
I currently have a single Powercolor PCS+OC R9 290 and want to add a second R9 290 preferably a second Powercolor PCS+OC R9 290 if I was to put 2 of these in the x16 and x8 slots of my Asus Maximus VI Formula there will be about 3mm of clearance between the backplate of the card in the x8 slot and the fans of the card running in the x16 slot.
My question is will 3mm of space be enough for the card in the x16 slot to breathe ? I have seen rigs at CES and E3 where 2 cards are practically touching and they seem to be ok but a nagging voice tells me its not advisable.
Next to getting full waterblocks for 2 Powercolor PCS+OC R9 290's the only option I can think of is getting something like a Asus Direct CU II R9 290 with a slimmer 2 slot cooler instead of my Powercolor's 2.5slot cooler putting the slimer card in the x16 slot and my Powercolor card in the x8 slot.
I had seen suggestions elsewhere about just buying a second Powercolor PCS+OC R9 290 putting 1 in the x16 slot and one in the x4 slot(slot 3) will this affect performance since both cards will be reduced to x4 speed ?
Any other ideas or suggestions would be appreciated as I'll be ordering a second GPU on July 18th
