Need New Speakers £75 or less
WYP
News Guru
Hey guys, I am looking for a new set of speakers for my PC, my price range is £75 or less, though I only want to spend the full amount if it really makes a big difference is quality.
ATM I am looking at the Microlab SOLO6c, which is £75.99.
Right now I am using integrated monitor speakers from my QNIX Korean 1440p panel, which is terribad.
Have you guys got any recommendations?
I really do not think you could go wrong with the choice you made there buddy :)
Cheers, I did some research beforehand, but I am not an Audio guy, so just want to make sure I'm not missing anything that should be considered.
I was initially going to go with the Microlab SOLO1c, but I hear these are much better.
Just make sure you have some decent cable connected to them QED used to be the stuff I used in the 80's I think it's 72 strand its one simple rule "the thicker the wire the lower the resistance" hope this helps
