Need help with PSU.
Mika
Hey, so I spent a lot of time in the past few weeks comparing and reviewing all kinds of parts for my new build and today I finaly completed it. Everything but the PSU, I am not 100% sure how much watt I need for my build and I was hoping to receive some help from you guys.
Note: I dont mind spending an extra 60$ +/- to get a semi or fully modular PSU.
Here is the spec.
PCPartPicker part list: http://ca.pcpartpicker.com/p/bBFt23
Price breakdown by merchant: http://ca.pcpartpicker.com/p/bBFt23/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1600 Memory
Storage: PNY CS2111 240GB 2.5" Solid State Drive
Storage: Western Digital Caviar Green 3TB 3.5" 5400RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card
Case: Phanteks Enthoo Pro ATX Full Tower Case
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System: Microsoft Windows 8.1 OEM (64-bit)
Thank you.
It tells you at the top of your partpicker list - 461W
My rule of thumb (others may disagree...) is to go with a power factor of 1.5 if you're going to run the system as standard, and a factor of 2 if you're going to overclock.
And you wouldn't be spending the extra bucks on a K CPU if you weren't going to overclock, so I'd recommend a 1000W PSU.
:confused: Why on earth would you even consider reconmending a 1000W PSU?? That is way overkill for OPs system.
OP a quality 650W would be plenty for you, unless you are considering a multi GPU config.
I personally prefer the following:
Silverstone, EVGA, Superflower, XFX, Corsair. Fractal are pretty decent too.
You dont want to over draw or under use a psu. you get maximum efficiency when you run them at a sweet spot which i think (and dont mind if i get corrected here) at about 60% of the max rated output.
