Need help with management.
  • Thread starter Thread starter Deleted member 9280
  • Start date Start date
D
Deleted member 9280
Guest
Have
Thermaltake Kandalf case and I have a nice and big PSU, but it isn't modular. I was just wondering what I can do about cable management? Currently I have all the unused cables outside the case hanging there, but I want to sort this out asap.
I have tried managing myself but can't think of having something perfect for airflow and look. I have tried hiding behind the mobo tray but it's too big to fit behind. I have tried leads next to each other, still nothing. I have also tried tucking under/in the drive bays.
The mobo tray has no holes for cable management.
Closeup
Bays
This will be the fans
What can I do?
or if you dont have a dremel drill some holes at the top for some cable ties and maybe neatly tuck it at the top.
There is holes @ the top of the case, but there is that many leads, seriously A LOT! This will look messy, I got dremel tool but just figuring out if I wonna do it lol.
Most likely will.
Pics lol.
Before(Not too bad I suppose)
After(slight improvement)
name='Kempez' said:
Might want to grab a rubber strip and put it on that hole mate
Not too bad though :)
I will do, not got any here though :D, will most likely do that tomorrow.
