Hey guys
I have some money spare since I bought my system last may and I want to upgrade it a little. I have been thinking about water cooling it since the day I bought it so I have been trying to educate myself on how to watercool.
What I am wondering is are these parts ok for my system listed below.
Cpu: intel 3930k overclocked to 4.6ghz at 1.35volts
Gpu: Evga gtx 680 reference 2gb overclocked by 120mhz gpu clock and 300mhz memory
Case: Coolermaster cosmos 2
The blocks I was looking at are
Cpu: XSPC raystorm
http://specialtech.co.uk/spshop/customer/product.php?productid=14598
Gpu: XSPC Razor full cover
Pump/res: XSPC X20 750L/ph 12v Pump and bay res
http://specialtech.co.uk/spshop/customer/product.php?productid=10479
Will this pump and res be sufficient for my system?
Radiators:
360mm in roof: XSPC EX 360mm Crossflow (will explain that in a sec)
240mm in base of case: XSPC EX 240mm
http://specialtech.co.uk/spshop/customer/product.php?productid=15447
http://specialtech.co.uk/spshop/customer/product.php?productid=14705
Will the combination of these radiators be enough for the cpu and gpu?
Coolant/dye/fittings etc
Right I am looking at using the mayhems dye and water
Dye:
http://specialtech.co.uk/spshop/customer/product.php?productid=16831
Water: http://specialtech.co.uk/spshop/customer/product.php?productid=12494
How much fluid would I need 1ltr or 2ltr?
Also what do you guys think of white fluid in a black case with an asus sabertooth x79 motherboard? Would it look good?
As for fittings I am thinking these
http://specialtech.co.uk/spshop/customer/product.php?productid=9832
Will these fit and how many should I need. I am thinking 10 but want to be sure.
Tubing:
http://specialtech.co.uk/spshop/customer/product.php?productid=5799
How much tubing would I need 1m-2m? Will this fit with the fittings above?
I am also thinking of using white leds in the water blocks of the cpu and gpu and res which I am thinking of setting up to the buttons on top of the cosmos 2 case which has an led on/off switch.
I am thinking of using the Corsair sp fans these ones to be exact
http://specialtech.co.uk/spshop/customer/product.php?productid=15960
I am thinking I will need 5 fans 3 for the 360 rad and 2 for the 240 rad. I am also thinking of going for the performance over the quite fans because I can hook them up the cases fan controller and lower the speed that way if they are too loud on full speed.
Here is a quick image of how I am thinking the loop should go together. Will this work or should I change anything?
Would I need a 90deg fitting from pump/res up to the rad? I am also thinking I may be able to hide the tube coming from the 240 rad to the res behind the motherboard tray and there is a good chunk of room but that would be something I would need to test.
So will this work any help is greatly appreciated as this will be my first time water cooling.
Thanks
Cpu: XSPC raystorm
Radiators:
Dye:
Tubing:
Thanks
