need help to plug my roccat kave to asus xonar dx
chiewleong
hey guys, i just bought roccat kave this afternoon (my 1st gaming headset).
now i dont know how to correctly plug the kave's jacks into xonar dx. especially the sub&center(orange jackplug) and rear speaker (black jackplug).
i have plug the center/sub jack and rear jack into their respective out jack, but there no sound coming out from it when i adjust the tip'n'control desktop remote.
any clue on that?
Thanks in advance for any help.
Ok well I'm at a bit of a loss as far as information goes, limited knowledge of the headset. But I guess all I can say looking at the connections on the headset would be to ...
Plug the USB into the motherboard
Green - Front
Pink - Line in/mic
Orange - C/Sub
Black - Rear
I'm assuming since the USB has a gray ring around it, that the usb is acting as the side audio, which is strange considering it is a 5.1 headset so my advice would be to make sure you've downloaded the drivers for the headset and see if that works. Also I'm thinking that it might be because you're using the soundcard I could suggest that you uninstall the soundcard drivers and install your motherboards audio and test it to see if it works if you feel like spending the time on that.
thanks lysol.
i tried connect to mobo. it just can adjust for front, but feel like all speaker fire at once. other didnt on when i tune off the front and adjust others.
and sorry for the misinformation. I will tried a few combination in morning. now is 12.30am at my place....
