Brooksie New member Nov 22, 2007 #1 Since I won that XSPC delta waterblock it's got me thinking about watercooling my new PC i'm building for Christmas. Heres the list so far, as a budget watercooling.. I'm looking in the region of around £150 to update that. Block isn't required - James
F FarFarAway New member Nov 22, 2007 #2 Personally I'd get slightly bigger tubung and use barbs, but Ham swears by compression fittings. I'd also get a 240mm RAD and a decent pump like a DDC
Brooksie New member Nov 22, 2007 #3 http://www.aqua-pcs.co.uk/flow-240-radiator-668-p.asp 240mm RAD http://www.aqua-pcs.co.uk/koolance-10mm--38-tubing-300mm-326-p.asp Will this tubing do? http://www.aqua-pcs.co.uk/hose-clamp-10-16-mm-397-p.asp Barbs? http://www.aqua-pcs.co.uk/xspc-bay-reservoir-black-410-p.asp Res http://www.aqua-pcs.co.uk/petras-tech-ddct-01s-delrin-pump-top-705-p.asp Pump?
Brooksie New member Nov 22, 2007 #4 Sorry for second post, but the only reason I went for a 120mm RAD was because I don't really want to external mount the RAD and link the tubing through and everything. *Looks for a bigger case *
M Marcus New member Nov 23, 2007 #7 You can fit a 240 rad in the roof of a PC-7 if you like. I have one spare downstairs which I have powdercoated and anodised, it will be put on ebay sometime next week if anyone is interested.
Brooksie New member Nov 23, 2007 #8 Yeah a roof mounting would be sweet, but as I said I don't want to cut the case (Unless I go through a slot)
M Marcus New member Nov 23, 2007 #9 When I said in the roof I did'nt mean externally... I meant internally. I'll PM you iin a minute!
Brooksie New member Nov 27, 2007 #10 Ok I've come down to: TJ09 but if my dad gets the job he applied for he said I get 1k for christmas so a TJ07
