PurE GaminG
advice on which gpu to buy
hi guys i need some advice once again i know im clown but a novice has to start somewhere.
first of all can you plz explain what to look for in a gpu when buying and what are you guys overclocking on the gpu
im planning on buying two gpu £300 total buget cant afford 670 and 680
motherboard Asus Maximums Formula Thunder FX need to order but still modding the case.
case cooler master cosmos 2
its going to be customized water-cooled top 360 or 420 and 2 dual 240 rads in bottom. dual loop
maybe get 850 corsair ax
function of rig
learning to edit in Photoshop and 3d rendering, gaming, watch movies blue ray and 3d movies
i want to have 3 monitors but because i do 3d stereoscopic rendering and watch 3d movies.
so i was thinking use 2 nividia cards 1 card to run 2 ips monitors and 1 3d montoir or three 3d monitors.
sorry dont no much about monitors
really dont know that's why im asking i know amd do infinity with 1 gpu but not sure about 3d any way i know you guys can advise and recommend me which way to go with explanation to why .
look forward to your advise
function of rig
