Need advice on new build.
Assertiation
Hello Everyone!
I'm in need of advice, I've been wanting to build myself a new rig for quite a while now but I don't know which parts to buy. I was hoping you, the OC3D Familiy, could help me with this one?
Will be used for:
Gaming
Rendering
And the everyday things like listening to music, browsing the web, etc..
I came up with this.
Intel i7 2600k €285
Asus P8P67 Pro/Evo €160/170
4GB Kingston HyperX DDR3 1600 €50
2x Samsung F3 1TB & 1x Crucial RealSSD 64GB 2x €50 & 1x €115
Gigabyte HD6850 €170
Sea Sonic M12II-620Bronze €90
Asus Xonar DX €60
Sony Optiarc AD-7260S €20
Scythe Kama Reader 2 €10
Total: €1060
Optional:
Logitech X-530 Speakers €70
Sennheiser HD 228 headphones €50
LG E2240S-PN 21.5" Monitor €135
Do you have any other suggestions?
Thanks in advance!
i would recommend that you go for 6 or 8GB Ram the rest seems ok
Think you'll need 4gb or 8gb with the new SB processors (dual channel) if you can try and get some mushkin nice ram.
hdd: good
ssd: may be a bit slow on the write speed
gpu: maybe a gtx 460 or a maybe a 6870 (or wait to see the gtx 560)
psu: seasonic are good I've heard
my thoughts anyhoo
do you need 2 tb of storage really? get a better gpu if you can afford it(not that the 6850 is bad but there are better) to give more futre proofing? roccat headset is a nice one for the money if you go for one.
All in all it personal choise tbh everyone has diff needs. i have an lg led screen and it awsome bt
Id say try and get mushkin ram and a 460 or 570 gpu.. 4gb ram should be enough.. You can get more if you feel you need it.
@inmate183 you would be suprised how much space doing graphics rendering and modelling takes up.. Ill be buying 2tb of space soon to mainly because of this :-)
