Need Advice On Networking
cowboy
hi every1 i need advice on networking 2 pc together #1 is the main 1 which is main in my bedroom with adsl which is a usb modem and #2 is my dads which is upstairs in a conveted loft he mainly whats the internet upstairs to browse the net and not for downloading i have an asus moard and i was thinking along the lines of there wifi card which is around £15 and am not sure if that would work right and i dont no which card my dad would need upstairs any help is greatful thanks in advance :confused:
cowboy
cowboy
read my similar thread on wireless networking in same section. mcmad and gorby were a BIG help - thanx guys
sw
yea gordy thanks got it stable at 3.9 temp is -35 idle and load is about -15 running prime95 the way u said now i just need to get some new memory and i will be sorted do u have the pc65 lian li case ?? if so have u noticed the normal cooling on it it seems to be very poor cooling coz my mobo temp is up and i cant seem to o/c my gpu much now i have got a home biult fan on my northbridge it has taken it down a bit but not much dont really want to got the watercooling way for my gpu and mobo any 1 else had this problem with cooling in the lian li pc65 case ????????
edit: right just looked at temp in my room with a temp gauge from outside and the room temp is 30 degree c which is good in a way but bad in another coz its not even mid summer right :(
I think the mobo temp on the p4c800 sensor is quite near the freezer head of the prommie which gets very hot have u taken temps with a probe from a fan controller or something?
