my watercooling Kit*Complete*
fadz23q
Okay so heres the List iv been recommended to get,thanks to friend on the Aussie forums ,theres just a few things i need abit of help with in which i havnt included names or brands of any sort for, so if anyone can go through that list and recommend me them, that would be great Cheers.
All fittings to be 1/2"
i will need a T-piece as well as a t-line plug of some sort,if someone could recommend it would be great
CPU block: DTek Fuzion
GPU block: EK fullcover block
Radiator: Thermochill 120.3PA
Pump: MCP355
Fans: 6,just not to sure to which brand i should be aiming for
and How many CFM each should be??
Tubing: Tygon 7/16"
Coolant Additive: Zerex
extras:
3 litres of de-ionised water and A bottle of Isopropyl alcohol for the first up flush out.
I would not put the Noctua NF-S12's on a Thermochill rad as they provide nowhere near the required static pressure for rad work. The NF-S12 was designed to achieve the highest possible airflow at the lowest possible noise level, not to set any records in terms of static pressure. Might want to have a look elsewhere mate ;)
name='Pat123' said:
Wat are the best fans for a a Rad?? when used in push pull config..
'For a rad' is like asking 'how long is a piece of string'!
High density fin rads such as BI stealths benefit from high cfm fans, the thermochill, I have 140cfm fans on a controller - at full blast they knock 1-2 degress off. At lowest setting (almost inaudible as far as deltas go) they are fine.
This is just my experience. There is a link on Thermochills website to a whole thread on thermochill rads, different fans push/pull etc...
