My Sarah Build
tengtium
Upgraded My Sarah Build.
just upgrade my sarah..
ASUS Z87 Maximus Formula VI with Free Watchdog (literally).. lol :D
need to cut the motherboard tray so that i can fit the psu at the back when the shroud already installed. because i don't have (UN)Designs Z2 holder for my reservoir i created a acrylic holder to mount it in my radiator.
psu shroud already finished. need to find where to put the holes for my pump and for gpu pci-e cable.
now all the holes cut.
http://i.imgur.com/FMfjfDk.jpg
put some fittings..
for pump
for radiator
for cpu block and motheboard
http://i.imgur.com/0lPwdJt.jpg
for reservoir
and gpu
putting all loop together by installing the tube.
put some simple drainage system at the radiator..
add some acrylic sheet to hold the hard drive at the side of the radiator. and do fair cable management at the back.
... now..
the finish product..
Core i5 4670k cooled by Supremancy Evo (upgrade)
Asus Maximus VI Formula
HyperX BluBlack 16GB DDR3 1600Mhz
Seagate 1TB 7200RPM
Seasonic X 650w Gold
CM Storm Scout 2
ASUS VS247H 23.6 Full HD LED Monitor (Black)
PALIT GeForce® GTX 760 JETSTREAM (2048MB GDDR5) cooled by EK-FC670 GTX
EK-KIT H3O 240 HFX (Reservoir, Pump and Radiator)
