My rig, still not finished though!
Signex
NZXT Phantom 410 White Rig
This rig is still wip, i'm still considering getting a other case like the Cosmos II.
And need more hard drives as i'm only using one 160gb sata atm.
Specs:
Motherboard: MSI Big Bang Z77 Mpower
CPU: Intel i5 3570k@4,4ghz (gets pretty hot though, 70c-80c)
CPU Cooler: Corsair H80i push pull
RAM: Corsair Dominator Platinum 8gb DDR3 1600mhz
GPU: Palit GTX670 2GB Jetstream (i was going for SLI but bought new speakers instead)
PSU: Corsair CX750m Modulair
Speakers: Onkyo HT-S4505 Silver
Soundcard: Asus Xonar D2X, this week.
Monitor: BenQ XL2420T 120hz 1080p
Mouse: Corsair M60
Keyboard: I used to have Corsair K90, but sold it cause i needed some money, will get one again.
Atm have a uber cheap logitech keyboard.
Thanks, yeah the loose cables are PCIE, they we're meant for a second 670.
I really hope to get a Cosmos II this month. :)
Looks good.
How does the M60 work on a wooden surface? Never tried any mouse without a mousepad, besides the old ball mouses :).
Thanks. :)
Works like a charm, never really used a mousepad, only once when i had a razer deathadder + razer goliath XXL.
I know, saw you're rig. :D
But one card is handling all games at 60fps with no problem, and i'm a huge audiophile.
So i really had to get rid of normal PC speakers and go for the high end with receivers. :)
Looks good so far! I would remove the top HDD cage for better airflow and move both the Harddrives to the lower bay.. If you can that is but from the pics it looks removable
Cables are fine tho, it's just the extra pci-e cable is laying there cause it was meant for my second gtx670.
id really consider something like an asus 144hz 24'' monitor before a case upgrade, that looks like a phantom case but old gen, and it should be able to fit at least two 240mm radiators without modding right?
edit - But man oh man that is a nice computer.
How is that cx750m? I'm very very interested in that PSU, do you think it has the juice to power up a 2nd card?
It's a phantom 410.
Me was told my older PSU could have easily run 2 of my cards.
It was a Enermax Liberty Dxx 620w.
I already got a brand new monitor, LG IPS277I-BN.
And yeah it fits a 240mm radiator in the top.
edit: Still, i'm not that happy with this LG screen, i might just upgrade that.
You mean the Asus VG248QE right? 144hz.
I'll put my screen up for sale and see how much i get for it, easily 200 euro i hope.
edit2: Hehehe how about stepping it up a bit, Dell Ultrasharp U2713HM 1440p monitor. :)
edit:2 oh man Rich_ i love you, upgrading my monitor would be much better!
Btw ASUS PB278Q is also looking extremely good, damn i'm so hyped about this, thanks again!!
Thank you very much. I really appreciate these comments. :)
edit: Just a update, i've changed my IPS LG screen to a 120hz BenQ XL2420T.
I'm very very happy with the upgrade!
Never going back to 60hz, not even if 1440p monitors get cheap!
