My rig(haf 932 watercooled)
Mgut91
hope you guys like my rig, took some time to get the watercooling done, but here is my rig
M4n98td evo
Amd phenom II x6 1075t
Haf 932 case
gainward gtx 580 good edition
xfx 750w modular
creative x-fi sound card
tp-link wirless card(really good after my opinion)
3x 1TB storage and 32GB ssd from crosair
4x2GB corsair vengeance ram
Now for the watercooling parts
dp-600p pump
tygon r-3603 tubes
dual bay reservior
3x gentle typhoon fans ap-14 and one blue sickle flow fan from cooler master
Tpc 360mm radiator 60mm thick
And here can you see the loop :D
Why is there a fan on the motherboard heatsink?
To achieve better airflow and looks in the case, of course :)
Huge pics man! Can you take a shot of the whole inside? So we can see how the loop's going around and cables ^_^
For how long is your watercooling system set up? Your tubes look green.
i know i have alot of room for overclocking, and i know my tubes look green or ugly, but i bought them used from a person, he had them around for a long time, havent had time to change them, the the fan on the heatsink is improving the temps on the mosfet or chipset, by 3 or 4 dagrees, but is the pictures to big?, tried to resize them using this link http://sqi.sh/links
edit: hope the pictures isn't so big now, used tinyurl now to resize them, hope you guys are happy, zstill new to this forum
waiting to add the extra 2 fans waiting for some trippel dust filter from techbay.no
and ofc i will remove the fan on heatsink on motherboard if you think it will improve looks, and as i said, the tubes did i buy used from a other person that had them laying around in his house, but sometime i will change them
yes, thanks god for that :D had some truble to resize them at first :P
i've removed the fan on the mosfet and i overclocked my cpu and gpu
cpu: 3.6GHz
Gpu: 900Mhz, shader: 1800Mhz and memory: 2200Mhz
and it is running stable when i am gaming
and never over 44 degrees when i have my fans running
when i am doing stress test with prime95 and msi kombustor, it gets 48 max on the gpu and 46-48 on cpu, so i still have room for more overclocking :D
pictures will come :D
