son of spanner
hi all
this is a build I've been working on for the last two days most of it is new parts but some of it is from my last rig I like to recycle lol
I was going to do a build log but I just jumped in and before I knew it I had done most of the mods lol
heres a run down of what I used
prodigy m
msi z97m gaming board
intel 4690k
8 gb of xms3 ram old but works
amd hd7950
corsair cx600m psu
240 gb ssd
ek pump res
ek cpu and gpu blocks
alphacool 30mm 240 mm rads
nzxt led kit
and im sure there's more that I forgot
the prodigy m is not very water cooling friendly but I like a challenge so I started by cutting out the floor of the case I made up some 25mm spacers for the fans and rad grill and the psu mount had to be cut down and lifted 15mm to clear the end tank of the rad they are the two big mods I did to make all the gear fit some of the of the small bits I did was to change the side panels round so the power reset is on the back so all the cables are mostly out of sight lol the build is about 90% there but I still have some ideas on how to add more room for a extra card lol
here are some pics
this case has been a lot of work but I have enjoyed it very much but as I said its only 90% there so you may see more to come just depends on money as always
prodigy m
intel 4690k
amd hd7950
corsair cx600m psu
240 gb ssd
ek pump res
nzxt led kit
here are some pics
