U unreal New member Jul 15, 2005 #1 Spec: DFI Ultra-D (5/10-2 Fix) 3200+ Winchester (w/ XP-120) 2*512mb Twinmos UTT AA4T Sapphire X850XT Dual DVI Seagate 120GB 7200.7 Tagan 480W UO1 Lian-Li PC-61 Opinions?
U unreal New member Jul 15, 2005 #3 GoLLuM4444 said: Very tidy. What clocks do you get out of that ram? Click to expand... See here Not alot now Nah I havent even had a chance to burn em in.. sadly
T The Legend New member Jul 15, 2005 #4 Tidy rig friend. Does that AKASA stuff work? Wots the pros and cons? Shame it dont come it bright white - I could see where I droped screws and stuff easier then LOL
U unreal New member Jul 15, 2005 #5 Akasa stuff is a waste of money and time. Firstly it increases case temps 2-5'c. It barely makes a difference to noise and is virtually impossible to remove.
G Grov Guest Jul 16, 2005 #6 Yeah, it's definatly a wicked looking rig. I might give mine a try at tidying, once im happy with everything, lol. How did you mount the extra fan at the front? I just tryed putting my HD's in the floppy cage, but there's not much cable room, and i think me Raptor would get a bit warm. I wanna stick a 80mm in the Floppy drive cage, gotta ask me dad to drill a hole in the fan, ehe. Now all you need is a side panel.
G Gangster New member Jul 16, 2005 #7 Unreal - have you tried using soap and removing the stuff that the akasa leaves behind. Done it on my wavemaster, came off after alot of elbow grease
U unreal New member Jul 16, 2005 #8 GangstaR said: Unreal - have you tried using soap and removing the stuff that the akasa leaves behind. Done it on my wavemaster, came off after alot of elbow grease Click to expand... Isopropyl alcohol
G Grov Guest Jul 16, 2005 #9 Heh, ive just zip tyed a 80mm in the floppy bay, perfect fit, eheh, but i doubt it does much at 7v. Ive got a bracket to use with a 120mm fan, to blow on me 7800, it gets hott.
U unreal New member Jul 16, 2005 #10 Grov said: Heh, ive just zip tyed a 80mm in the floppy bay, perfect fit, eheh, but i doubt it does much at 7v. Ive got a bracket to use with a 120mm fan, to blow on me 7800, it gets hott. Click to expand... You coulda got a 92mm in there like I showed you! Zalman bracket?
U unreal New member Jul 17, 2005 #12 name='Grov' said: I don't have a 92mm. Click to expand... Mines a loud ass Antec thats louder than stock 80mm's (12v) at 7v!
