my new 3800+ venice r507 chilled.
Dazboots
just started turning the screws up on my 3800+ venice.
had this baby to 3.3 ghz stable..........1.68 volts..
does 3 ghz on stock 1.4 volts.
this memory wont go high as my cpu.
so im running dividers on the memory so not 1:1
going to get some gskill . then 1:1 will be much quicker.......
got 110K aquamark and 26 seconds super pi...
will easy get 25 seconds.......
http://img209.echo.cx/img209/2985/screenhunter0178mr.jpg
just completed 32 meg super pi first run.
did it in 23 min 17 seconds......
http://img167.echo.cx/img167/3213/screenhunter0233mh.jpg
http://valid.x86-secret.com/show_oc?id=14033
I feel like I'm repeating myself lol
Great work Daz :cool:
Get that thing burned in, and we'll see how far you can push it...
Still not sure if it's quite an FX-55, but if it'll scale further with voltage, it might just be a better alternative...
If this is what the 90nm does on 512, the sandiego should rock the house :D
Gray
Excellent work Daz,
Keep posting them results my friend - u got us all wanting to hear more about the latest AMD wonder chip.
Post your system specs here too - give everyone an idea about what the will need to get similar performance.
Cheers
Mav
name='fatty' said:
Nice 1 we want more Daz see what the max is what timmings you using fsb etc
this ram will only do 264 fsb 1:1
thats 3164 mhz
but if i use dividers and dont go 1:1 had it to 3.3 ghz stable.
need some better ram........ some gskill......
bet when i get this cpu burned in i shud be hitting 3350 mhz stable.....
just priming torture tests now for a while....
Sorry, forgot to add,
Have you tried it with 4 sticks of ram yet?
Stretch that mem controller to it's full potential?
Also, I thought 1.55v was the 'safe' limit?? Then again, Daz whebever have you played it safe!! :D
maverik-sg1 said:
Excellent work Daz,
Cheers
Mav
thx m8....
my system specs
mach 2 regassed to r507
3800+ venice cpu
4x 512 meg ocz pc4000 vx memory
dfi nf4 d-r- motherboard
2x leadtek 6800 ultras
ehiem 1250 pump
2x dangerden water bay res
blackice extreme rad
phillips external sound card
creative i truigue speakers
2x 74 gig raptors stripped raid 0
250 gig external hard drive 16 meg cache
2x dangerden actel waterblocks
24 inch dell tft widescreen
enermax sli 600 watt psu
logitech dinivo mouse + keyboard.
there u go m8...... ;)
Sweet cpu my fx 55 will do 3.3 unstable but 295 x 11 all day long satble so I just keep it there I didnt even realy burn it in I may be able to get more out of her??
Daz,
Gskill LE does 300 @ 2.5-3-3-7 3.1v
Probably goes higher but my cpu wont go above 300HTT (even with dividers etc....).
Cheers
Mav
maverik-sg1 said:
Daz,
Can't open the link mate, not a bad score.
Fully loaded with windows my FX55 at 268x12 will do 23m07s so that's an impressive score with your venice my friend.
The BH5 I was after is the stuff you had that did 270 @ 2-2-2-6 as per your post earlier this month on this forum - if thats OK?
http://www.extremeprometeia.com/forum/showthread.php?t=1970
Cheers
Mav
its 2 x 256 meg m8.......... but its like rocking hore ****. is this.......
if u want it its yours........
Nah mate I need 2x512MB, make an offer if you want it though, I need BH5 2x512MB that will run 250HTT on non NF4 mobo or 270 on NF4 mobo.
Fatty, how do I find the week (too lazy to open the shuttle to check).
Cheers
Mav
