My mission...
tc_overclocker
Ok... so I'm big into benching... have been for some time now.. and on another forum that I'm a regular visitor 2 there is a big league for us 3DMarkers....
Now I purchased an ST off our friend Phil last week to start clocking me A64 3200+ ready... and this is what I'm at so far after having the ST on for 1 and a half days :P
This is fully stable after running Toast for a night and half a day... tis currently running now as well... so within the week it should be higher... it will 3DMark about 5 Mhz higher presently... so I'm hoping for some 270x10 action by the time I've finished burning in...
Obviously this isn't a stock mainboard that this is running on... it's the Shuttle AN50R with the vDimm mod done and presently 3.5v are going through the memory to keep it stable at this speed :P
Next job is to rig up the pelt on the XT to see what scores I can manage... and I will report back..
... until then..
TC over and out...
sounds like bad contact, i had that before i tightened all teh screws and re applied string seal nearer to the edges.
after doing this i was went from -20 idle to -40 and +20 load to -22 on my P4
