My mini 8800gt review
Vrykyl
Ok folks, its possibly a bit low end for here, but iv been playing with an 8800gt today, and iv posted a quick write up here -
*snip*
I cant try and overclock it, its not mine and the owner doesnt want to, and I know the deliberate cpu/ram system clocks I used are low for here, but i thought maybe some of you might find it helpful?
theres problems with DOA and fast failure??!?
Thats news to me :S
Nice review, and nice numbers too :)
K
yup, quite a lot of folks I know who have actually managed to get an 8800gt have had them turn up doa or artifacting at stock speeds. Cant remember which etailer it was, but one of them was saying of all the gt units theyve had, just under 20% of stock has been returned as faulty :/
Nice little dust up there mate seems the mighty current 640mb gts just got pwnd by a cheaper variant.
06 scores are especially imressive - can you use rivatuner to up the shader clocks on ure GTS to around the 1575 mark to see if that closes the gap?
I only ask coz the shader clocks on the GT are so high already.
The 7900GT had that problem, but from what I can tell, not enough GTs have been available for any real patterns to be noticed? :?
Mav, just for you matey I'v just rerun all tests on my 8800gts,but with clock speeds boosted to exactly match those of the 8800gt.
So my 640mb 8800gts was overclocked to: 660mhz core, 900mhz memory, 1620mhz shader. 1 hour atitool artifact free :)
So if i copy and paste my 8800gt scores but update the 8800gts compartive numbers we get:
Crysis
640mb 8800gts Overclocked - Average fps: 24.72
512mb 8800gt - Factory OC - Average fps: 26.42
World In Conflict -
640mb 8800gts Overclocked - Min 23fps, Max 92fps, Average 43fps
512mb 8800gt - Factory OC - - Min 26fps, Max 96fps, Average 47fps
Aquamark - default settings.
640mb 8800gts Overclocked- 170,024
512mb 8800gt - Factory OC- 165,333
3dMark 2005 - default settings.
640mb 8800gts Overclocked- 18,214
512mb 8800gt - Factory OC - 18,795
3dMark 2006 - default settings.
640mb 8800gts Overclocked- 12,904
512mb 8800gt - Factory OC - 13,493
So at same clock speeds its simply the extra pipelines giving a little extra boost to the 8800gt....
For that OC i turned the gts fan to 100% - load temps of 75*c when clocked
LOL, was the first time I had ever overclocked the gts since new, just whacked the rivatuner sliders up to gt speed and fired up atitool :p
The problem is that the fan does not spin enough: 29% at 80 degrees C. I think that's why they break (put it up to 100% and the card never gets above 65 degrees)
yup....the heatsink/fan on the 8800gt is a big POS....imo yes the card is only £160...but add another £30+ for a heatsink that'l actually keep it alive :P
The DOA problem is due to crappy foxconn and their half-rate cards. Idk when the flextronics cards are out maybe they are the thousands that are coming into stock on the 16th, yep thats tomorow.
HR-03GT ftw.
www.71668.net 45
http://forum.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG]zhanjianshe.htm]网站建设常用的方法包括电子刊物、会员通讯、专业服务商的电子邮件广告等。 基于用户许可的Email营销与滥发邮件(Spam)不同,许可营销比传统的推广方式或未经许可的Email营销具有明显的优势,比如可以减少广告对用户的滋扰、增加潜在客户定位的准确度、增强与客户的关系、提高品牌忠诚度等。  3. 资源合作网站推广公司方法 http://forum.overclock3d.net/oc3d_gfx/smilies/cussing.gif[/IMG]zhanyouhua.htm]网站优化通过网站交换链接、交换广告、内容合作、用户资源合作等方式,在具有类似目标网站之间实现互相网站推广的目的,其中最常用的资源合作方式为网站链接策略,利用合作伙伴之间网站访问量资源合作互为网站推广。 每个企业网站均可以拥有自己的资源,这种资源可以表现为一定的访问量、注册用户信息、有价值的内容和功能、网络广告空间等,利用网站的资源与合作伙伴开展合作,实现资源共享,共同扩大收益的目的。在这些资源合作形式中,交换链接是最简单的一种合作方式,调查表明也是新网站推广的有效方式之一。交换链接或称互惠链接,是具有一定互补优势的网站之间的简单合作形式,即分别在自己的网站上放置对方网站的LOGO或网站名称并设置对方网站的超级链接,使得用户可以从合作网站中发现自己的网站,达到互相推广的目。交换链接的作用主要表现在几个方面:获得访问量、增加用户浏览时的印象、在搜索引擎网站推广中增加优势、通过合作网站的推荐增加访问者的可信度等。交换链接还有比是否可以取得直接效果更深一层的意义,一般来说,每个网站都倾向于链接价值高的其他网站,因此获得其他网站的链接也就意味着获得了于合作伙伴和一个领域内同类网站的认可。 4. 信息发布网站推广方法 北京google排名将有关的网站推广信息发布在其他潜在用户可能访问的网站上,利用用户在这些网站获取信息的机会实现网站推广的目的,适用于这些信息发布的网站包括在线黄页、分类广告、论坛、博客网站、供求信息平台、行业网站等。信息发布是免费网站推广的常用方法之一。  5. 快捷网址网站推广方法 即合理利用网络实名、通用网址以及其他类似的关键词网站快捷访问方式来实现网站推广的方法。快捷网址使用自然语言和网站URL建立其对应关系,这对于习惯于使用中文的用户来说,提供了极大的方便,用户只需输入比英文网址要更加容易记忆的快捷网址就可以访问网站,用自己的母语或者其他简单的词汇为网站“更换”一个更好记忆、更容易体现品牌形象的网址,例如选择企业名称或者商标、主要产品名称等作为中文网址,这样可以大大弥补英文网址不便于宣传的缺陷,因为在网址推广方面有一定的价值。随着企业注册快捷网址数量的增加,这些快捷网址用户数据可也相当于一个搜索引擎,这样,当用户利用某个关键词检索时,即使与某网站注册的中文网址并不一致,同样存在被用户发现的机会。 6. 网络广告网站推广方法 google优化网络广告是常用的网络营销策略之一,google优化技术在网络品牌、产品促销、网站推广等方面均有明显作用。网络广告的常见形式包括:BANNER广告、关键词广告、分类广告、赞助式广告、Email广告等
