Hey guys! (posted on another forum aswell)
I have problem with this new Bios update
Z97-DELUXE BIOS 1304
since I updated to it I can't get it to downlock in voltage when its idle (800mhz+)
its stuck on the same voltage that I put in (1.260)
these are the settings I have tried
C-states on Auto and enabled
Epu settings on enabled
Balanced on power settings in windows with Minimum processor state 5%
I have checked so the switches on my motherboard is on default (not oc mode) and epu switch is on.
I feel like I have checked everything that has something to do with powersaving in BIOS
it all worked fine with these settings on when I used the older Bios before the new one (1203)
anyone have an idea what the problem is that is making my cpu stay on the same voltage all the time?
should I go back to BIOS 1203 maybe ?
had it stable 4.6ghz @ 1.260v on all cores at 1203 bios
anyway thats my problem Im having. been working on it for hours.
/Max
/Max
