my haf build
tonkin97
after 2 months i got round to cable tidying and management, i did the best i could at the back but due to the size of the case and ammount of hdds i got wasnt easy. ive also modded a fan at the 5inch bays to suck air in taken advantage of the dust filters on the drive bays, some may like others may hate it, but it feeds my noctua in my very hot room and the temps jumped down by 5 degrees since ive put it in, its very quiet system aswell.
my specs
Case: 922 haf coolmaster
CPU: 3.926Ghz amd quad core 965 black edition running on 1.38 volts
Ram: Corsair xm3 clocked just over 1600mhz
Motherboard: asus croshair iv formular
HDD: im running a raid 0 with 3 drives saving for a sata 3 ssd and i have 2x2tb raid 1 for storage
yep i know ttl will go nuts over that but short cables for a large case bad plus i dint want any fan cables on the board or the chance of them knocking into fans
i know the fan is slightly dirty
i used cable ties and tightend alot so i dont get vibration
