My first ever build !!!
mopblond
so i recently just completed my first ever pc build, i loved doing it and its thanks to forums like these and the reviews etc that i was able to learn enough to take the plunge and attempt a build, a big thanks to all the posts and info on this forum it really helped so here it is my first build it took me a month round about alot of hard work as not much access to tools but i loved every second of it :) thanks again and all constructive criticism is welcome :)
components
intel i5-4690k
16gb hyper x ram white 1866
corsair H100i
corsair H55
asus Z97 pro
amd R9 290x
kracken g10 bracket white
Samsung evo 840 120gb ssd
2tb seagate hard drive
bitfenix alchemy 30cm white led
corsair ax1200w psu
3x corsair PWM static pressure fans
3x corsair airflow white led fans
corsair red sleved cables
materials
perspex acrylic 3mm
3m carbon fiber vinyl
card paper lots of it!!
tools
30cm ruler
broken set square
junior hack saw
un grounded bare cable drill (got many and electric shock)
craft knife
eventually had to invest in a dremel and the thing is fantastic will never go back, once i got it wanted to cut everything i saw up!!!
so on with the build i suppose too start i had to decide on a case which was incredibly hard with so many to choose from and all offering different things, i eventually came across the corsair 600t which once i saw i instantly loved and had to get it, a great all round case that was fantastic too mod. like i say with limited tools and no access to any design programs decent power tools or cad machines this will by no means be a professional build but i loved doing it none the less.
unfortunately i cat upload photos so please follow the link for now :)
Just edit your original post and Ill delete all the replies to clean things up....... (it will need approving when you put the pics in so dont panic and try to get it all right before hitting save)
