My Final Draft (screenshot)
  • Thread starter Thread starter Kyle
  • Start date Start date
K
Kyle
Guest
Hi guys, haven't been here in a while, just wanted some last tips before I order my new/first rig
Intel Core i5-3570K 3.4GHz LGA1155 Quad Core Ivy Bridge CPU
Coolermaster Cosmos II Black RC-1200-KKN1 XL-ATX Chassis
Gigabyte Osmium USB3.0 Cherry MX Red Switch Mechanical Gaming Keyboard
OCZ VTX4-25SAT3-128G 128GB Vertex 4 Series SATA III 2.5" Solid State Drive
5M HDMI Male to HDMI Male Cable
Corsair CMZ8GX3M2A1866C9B Vengeance With Blue Heatsink 2X4GB Kit DDR3-1866 CL9 1.5v Desktop Memory
MSI GTX660Ti 2GB Power Edition OC 192-Bit PCI-E 3.0 28nm Desktop Graphics Card
MSI Z77A-G43 LGA 1155 ATX Intel Z77 Desktop Motherboard
Corsair GS700, ATX 12V V2.3 - 700W (12v: 672W), 80PLUS White Certified Power Supply
Crucial M4 would be my choice , not the OCZ one..........
you will hear this more then ones tho.........
wow and it's a bit cheaper. thanks! is it just the controller that's better?
Hmm now you mention that i remember a disscusion about this,
that it was indeed just the controller used in the SSD's..
so i think you are correct about this...
hi, i just found an interesting forum post with regards to this issue. if you look at post 7, the vertex 4 looks a lot better than the m4... would this be one of those times where benchmark don't reflect the real performance?
sorry forgot link -link removed-
Thank mate,
personally i would still go for the Crucial one ,
but that's because i had some bad experience with OCZ ,
and overall i think people would go for the Crucial one...
never heard about a Crucial one dying,
yet i do hear that about the OCZ series...
Good luck buddy ,.Ray...
now i don't know... should i just go for the cheaper one and invest the saved money in an msi g45 instead of g43?
one 660 ti but i don't want to close all my doors yet :), that's why i was thinking of g45. i also heard the heatsinks are better
A tad bit better, yes. Ironically I built a system with the G45 last night :P It's a decent board and the heat sink is a little better.
so it's worth dropping down to the m4 for the replacement of the board to g45?
I wouldn't buy the cosmos 2 if you're not going to fully watercool it. Get a cheaper case like the CM Storm Stryker or the Corsair 650d and get a better motherboard like the MSI z77a-gd55.
well i'm trying to future-proof the case so i never feel the urge to upgrade it in the future, should i decide to put some insane water configuration in it
