My current setup.
The_Airborn
Well, it's beggining to show some strain so iwill get a new one when i have enough money...
CPU: AMD Phenom II x6 1100T @ 4.0 GHz
RAM: 8Gb Corsair Vengeance 1600
MB: ASUS Xtreme Design M4A89GTD PRO
GPU: 2x XFX Radeon HD 6950 1gb
SSD: Corsair Force GT 240 Gb (BD Win 8)
Corsair performance pro 128 Gb (BD Win 7)
Corsair SSD Force F60A 60 Gb
HDD: Seagate Barracuda 7200 1TB
PSU: Chiftec Nitro BPS-750C 750W
Case: Corsair 600T
i like! and as the others say, not shit in the slightest. Only thing i would change is if you have the room. Move the SSD down to the lower HDD tray and then slide that tray across to hide the PSU cables. Then you can remove the top one completely and this should help a tiny bit with regards to airflow to your GPUs
Edit. I just noticed you have 3 SSD's in there already plus your harddrive my bad. I can't remember if you can slide the top one over without having to remove the bottom one but if anyone knows?
Oh stop it you ;) Well i guess it's still pretty good but i forgot to mention one of the GPU's are a little bit faulty. It won't send out a signal over one of the DVI ports and it's choppy as shit, but i can atleast get some decent FPS in CfX. I guess my standards are a little bit high with all the YouTube videos of awesome systems and such :)
Looks like such a nice rig to me, its not shit :)
P.s have you tried running the one faulty GPU on its own? you may be getting close to your power output of 750W..
It means my standards should also be high! My Computer compared to your so called "SH*T" computer is truly SH*T. If I were you, I'd be grateful... that you're not in my position or in any others with a crappy PC ;) :D :lol:
