My £150 eBay bargain...
almighty15
My £150 bargain!!
This is it currently, being completely striped and is currently at the powder coaters....
Phase unit before
Primer
Paint drying.
2500k 24/7 clock
Everything should be back from the powder coaters ready for reassembly next week....
2500K at 5.3ghz? Thats not gonna last for long
its hard to explain but the essence is that it is a combination of temperature and voltage that cause the atoms in the chip to move, therefore eventually breaking it, well because you take the heat element away so far into the negatives, it substantially reduces the effect
Max safe is 1.52v and I'm running it at 1.5v at -33c
Sub-zero massively reduces electron migration and infact my chip at that voltage is possibly safer then your chips on air or water because of how cold it is, my 2500k loads a good 80c colder then the average 2500k
Oh was that just the cooling for £150? I thought that was the case :L
It looks good - not sure if it's want it in my system unless it was just a little project - which spending 600-800 quid would be a little expensive :)
Damn that looks cool and very nice results! Instant buy for me, although I doubt I'll ever see this passing by though.
How is the power consumption like?
Phase unit pulls around 250w during load and around 220w at idle, it is high but when you work it out on a monthly basis it's not actually that bad in terms of extra cost.
I'm on 13p per Kw/h so it's costing like 13p for 4 hours...
Thats indeed not that bad. Any chance you can split up the cooling and cool the GPU as well? That would really be a cool thing.
Not without a decent amount of work and tbh there's no real need to use it on GPU's as they don't benefit from the cold as much as CPU's do.
