Mushkin RAM for new Gigabyte UD4 board
happyshoppa2
Hey guys,
Super quick question, is this RAM alright for this board?
Mushkin 8GB (2x4GB) DDR3 PC3-12800 9-9-9-24 Blackline
https://www.aria.co.uk/Products/Com...+9-9-9-24+Blackline+-+996776+?productId=43028
Gigabyte GA-P67A-UD4
https://www.aria.co.uk/Products/Com...DDR3+PCI-Express+Motherboard+?productId=42994
Or would you recommend something different? Quite fancy something black to go with the board, and the 2000mhz stuff is only in 2gb sticks which leaves me a bit too limited in how much I can add overall.
Getting the 2600k with these btw.
Thanks.
The mem dividers with sandy is 1333, 1600, 1866, 2133
Because there is no real usable BCLK overclocking it best to buy the ram speed you want.
Obv that mushkin will be ok at 1866 but it probably wont do the next notch up which is 2133.
Thanks guys.
I guess I'm unsure how much difference in will make in reality between 1600 and 2000, I've never noticed much diff with memory speed before. Think I'll go for the 4gb sticks at 1600, will be doing 3d rendering so the extra ram will probably be more useful than the speed.
