MSI confirms plan to support AMD's Ryzen 5000/4000 series CPUs on all its AM4 boards
Not 100% just yet, but most likely between 5700x 5800x or the 5800x3d, really depends on the difference between them and price and if the x3d is able on my x370 i'll know before i pick one up at least. My main reason for holding back on an upgrade generally is the mobo is tied to my windows install, so changing that would have meant tons of hours reinstalling.
So this solves that issue and will make my system last a while longer, my only main issue after upgrading is how to force windows to not install windows 11 i'd rather it not upgrade me just cause it can as atm i see no reason to get it.
So I'll be looking out for comparison benches on them 3 cpu's i know the x3d has no overclocking so unless it outperforms an oc'd 5700x or 5800x i'll mark it off the list.
update:
After a little looking around if the 5800x is supported it's at not a bad price atm so i'd be able to get one around the time of the bios update, thou if i could get a 5700x for a similar price i feel i'd lean towards that as it has a lower TDP not sure the x3d is really something i'd need and it's bound to be a little higher in price.
Saying that good news for me, my 6800XT will finally be able to open the taps fully :D
Well colour me surprised. 5800X going to be a on the shopping list now :D
Yep sure is good news, been waiting a long time hoping that AM4 would get full support across the board and it now seems that is happening. So my next upgrade after this one will be a long time off, tech moves to fast to keep up fully and so maybe when AM6 happens i'll be chomping at the bit to get an upgrade :)
