Azurite
Ok so i wanna monitor my gpu while gaming. I have read trough the manual and also made some adjustments. In the monitoring section i have enabled gpu temp and usage in OSD. I wanted to monitor how mutch gpu memory im using and also the fps. The fps in afterb is unhocked and there is no option for memory usage.
So do i need to run fraps and another program to monitor the fps and memory?
I see i can run many programs in the Rivatuner apps profile properties but i dont know how it works. What do use for monitoring the memory usage?
Edit: i managed to get the framerate monitoring so now i only need the memory usage fixed
Edit: seems like the memory usage monitoring only were availeble in the beta 2.2
