TheRusskiy
I installed MSI Afterburner to capture game video, but it doesn't.
Using latest beta version, before that tried non-beta
I have no idea if overclocking would work but nothing else works for sure(sensors work though)
Tried to restart PC, disable antivirus, disable crossfire, run as administrator - didn't help
Hotkeys work(i simply pressed "Toggle on screen display" hotkey and it changed state in OSD server)
:bang:
Strangely i can't find any other cases similar to mine on the internet.
Fraps works fine but i need better performance
I assume problem is in OSD server since nothing of the mentioned above would work without it properly functioning. May be something interferes with it? Or may be it can't see application running?
:bang:
