DP2.0 isn't really needed at this res/refresh rate, The monitor wouldn't really make use of it and it would only serve to increase the price. Only once you exceed 4K120 at 10 bit would it be a nice feature if you don't like DSC.
My monitor uses DSC at 4K 240Hz 10 bit, I've done blind A/B tests and honestly I cannot tell a difference in visual quality or any other metric, I'm guessing DSC will be used less and less going forward though with DP2.0 monitors slowly rolling out.
I feel like we had this discussion before some time ago with the Samsung G7 monitors. Never experienced DSC on a 4k Monitor, would be interesting to see the comparison.
