Not sure what revision the mobo is, I cant really see it on the board now, its pretty packed out in my computer now with the prommy, and tec gpu cooling + meanwell psu and water cooling system, including two rads mounted in the case. I just flashed to latest version bios 1019. I'd be interested in hearing what you got with that mobo, and whether you are having the same voltage problem i'm having being unable to use voltage settings above 1.6v(1.6v really being equal to 1.48 + droop at load.) This really puts the brakes on with my overclock. I really need to get a new motherboard, anyone got any suggests for a good socket 478. I had two max3's which i blew up a while back, but i think i know where i went wrong now, I think I was pulling the mosfet heatsinks of the mosfets when i was mounting the board, so I never really got to see what these boards where capable of. When i rebuilt the computer with upgraded cooling on the weekend i did try and do a droop mod, which wasn't successful, i broke off two of the solder points on the board, so went for the alt location on that resistor. Managed to get it on a couple of times but it kept falling off when i insalled the prommy head unit, sinces it sits over the point where the resistor is on the mobo
However this issue is nothing to do with my board mods since this issue existed before, I just didn't pay much attention to it before, since the water cooling wasn't enough to justify these high voltages.
Actually cpu-z says revision 1.xx is there a rev 2 or something?
Anyone else on this forum using a prommy on a socket478 board if so which one and hows it working out on that board. I used to swear by asus but this voltage thing is really annoying, i'd like to know if its a common fault or just my board.
I'm thinking that I should undo the prommy head and check to see if theres any as ceramic on cpu spreader since i applied it to the prommy head, then clean it all off and apply a thinner layer, what do you think? Then when i recover from the ridiculous sums of money that i've spent recently I might buy a new motherboard, i'm just not sure whether i should go for the same one or a different one. I think if I got the same one i'd be able to do the droop mod now since I have had practice, I cant do it on this board now cause any more contact with a soldering iron would probably kill it (all the droop mod contact points have seen better days)
