Motherboard heating up?
Dawelio
Active member
Hey guys,
So first off, I'm not sure if this is the correct place to post this, so please move to appropriate section if that's the case.
Now, I noticed this about a week ago or so... I haven't been on my PC much lately, much due to work. So I've only seen this a few times since then.
But obviously I'm getting really worried now, that it goes around 111-113 degrees on this specific one. And as far as my knowledge with Corsair Link goes, I haven't been able to find out where on the motherboard it is detecting this temperature, through Corsair Link.
So any help would be highly appreciated. Might it be a bug?... Do I need to worry?. Can the motherboard be faulty?... Should I get a new board? (maybe a good idea, since I broke the "lock" of the PCI Express lane once lol, so the graphics card is basically just resting inside the slot and not actually being "locked in" so to speak.)
My specs are the following:
i7 4790K stock
ASUS Z97I-PLUS
16GB Corsair Vengeance Pro 1600MHz
MSI GTX 980Ti 6G Gaming
Corsair H100i
Corsair HX750i
Corsair Commander Mini
Corsair 380T
Thank you,
Chrazey
Isn't there a new version of Corsair Link i'm sure i seen the new one in one of the Tek Syndcate CES video.
Could be just a bad reading dude do you have any other temp reading software.
But then, how am I suppose to know which one or where that temp really is?... When I don't even know what Corsair Link is actually indicating...
Well first step is to check the bios to see if there is any reading that is stupidly high then we can go from there :)
Ahh yes, that is what I was lurking for in my previous post. But then, basically to just look after any stupidly high temperatures in the bios itself.
Also any chance you've got HWinfo on ur pc?
Nope, not sure what that is :p... Some info reading software I assume? ^_^
This is HWINFO, Really handy software, I use it along with Rivatuner to display temps, Clocks etc.... ingame :)
Download the latest 64 bit version -
http://www.fosshub.com/HWiNFO.html/hw64_513_2750.zip
