More to come from NVIDIA
Mr. Popo
The Inquirer version:
The Inquirer said:
Nvidia beavering away on a Geforce 8950 GX2 card
Cuda, woulda, shoulda
CUDA is Nvidia's name for a GPGPU.
The acronym actually stands for Compute Unified Device Architecture. The CUDA marchitecture is apparently a fundamentally new computing marchitecture for the GPU to solve complex computational problems across consumer, business, and technical industries. At least that is what Nvidia says about it. And CUDA demands a dual Geforce 8950 GX2 as this means more computation power.
Nvidia entered this market later than ATI but it still has a lot of success as it has G80 that can do a lot of pixel and Shader operations. G80 is still the fastest graphics chip on the market. It has 128 Shaders and can process a lot of pixels. Therefore it is good for GPGPU or CUDA calculations as these science calculations are run on a graphics card disguised as a small Shader programs.
As G80 has 128 Shaders and apparently Geforce 8900 GTX is supposed to have 25 percent more Shader power, the new Geforce 8950 GX2 card should provide a lot more Shader and Pixel power. The card is demanded and we believe that Nvidia already has the design but we don’t know about any possible announcement.
If Nvidia ever sorts out its quad chip driver this means Quad G80 could be on the horizon - or however they later call this product. Yeah, graphics chips these days are big, hot and crazy.
Source
Well it's wrong!
Here is the OC3D version of it. :cool:
Mr. Popo said:
NVIDIA saved its best hidden?
Apparently the upcoming GeForce 8900GTX is more than just higher frequencies.
The GeForce 8900 will probably use an 80nm chip, and will be announced just in time to compete with the R600.
If this is true, NVIDIA has pulled a fast one on AMD-ATI.
Also a dual PCB and GPU configuration card (Just like the mighty 7950GX2) is expected.
Source
