JezEngland
OK. AMD is a budget manufacturer you'll get what you pay for and loose long term with AMD stuff unless your just an ebay'r so don't OC it might crash near the end of an auction
sorry!
Intel chip components are alot higher high-tec i believe and comparing AMD and nVidia GPU's both use the same chip manufacturer I read and nVidia buys the better components, that reflects their R.R.P GPUs' being more than AMD's
That's probably a fair idea, I'm not clued up realy and I always can admire the idea, quality over quantity so if we can afford quality even with a little stretch or so it's worth it
