Monitor Flickering Issue
MrKambo
I recently got the Asus MX239H, and i noticed that the bottom right of the screen in about 30% of the area is flickering, like the refresh rate type flicker, not image flicker
is my monitor on its way out?
ive tried 2 different cables on both the ports and still the same, even switch the video cards and drivers, still the same!
Then you have the right to send it back whit a RMA and get it fix, How big a area is it ? in cm if you will that sweet ;)
Edit : 30 % is to high, if you have a pixel fail rate on 8 to 12 that is fair. But 30 % is to damn high.
That is to high a area, so call overclockers and make a RMA monday or when you have the time. The only thing you can do, have tryed that my self in the pass whit a Samsung screen and got it fix in 2 weeks. But that is in Denmark.
