Modern Warfare 2, Won't load Invasion Level
k4p84
Hi all,
I've hit a bit of a snag here.
When I get to this level I get an error message saying.
can't load invasion.ffl
Anyone got any ideas if there is a fix ??
Ed
Doubt it is the disk as the files will be read from the HDD. Disk should only be used as a security check when the game starts up.
Tried a fresh install? Or even looking to see if others are having the issue?
Hi
Yer it's a retail disk(s).
I have tried googling but mainly I get ''why won't my copy activate before the release date.... ''
Anyone come across missing levels before?
Ed
I had something like this with Dirt for PC, it wouldn't install, I took it back to GAME, they attempted to install it and something on the disk was corrupt, gave me a new one.
That'll be a pain but I guess I'll have to give it a go.
Ed
but it copies those files from the disk in the first place.
Hi all
I got this sorted by reinstalling the bugger again.
Then I got hit by an IW4.exe error, ie basically the same as the pesky IW3.exe error you get in COD4.
Plug in a mic and all is fine.
You would have thought they would have learnt from their prior mistake.
Ah well.
Finished the game, now messing about in multiplayer
Ed
