Metallic Red PC60 Plus
Phil Stanbridge
Here's my baby. A metallic red PC60 Plus modified for the PA160. It's running a X2 4800 @ 35 degrees idle @ 2.7ghz virtually silent. It's a 24/7 system and has been totally reliable to date. She doesnt get switched off.
Loving the work u done there mate - great stuff, temps are really good, I'm sure there's 2.8Ghz in there though ;)
On stock volts I could push up to 235Mhz on phase, so 230 should be easily reached - not that you need the power, but if you were to switch to a PA120.2, could be a great option for your customers.
Don't forget to update the pics as previously discussed in other threads.
Mav
I LOVE that colour, great custom window too, subtle but looks great, i would just change the fan grills to EPUK ones and that would be it.
How do you rate the PC60 Plus phil as a case to work with, i was thinking of using one for a project this summer but wasnt sure.
G
phil mind me asking what happened to that innovtek controller, if u still ahve it i may take it off u as logn as teh red is same as mine and also maybe some new grills on yr case woudl be nice :p - poss ep-uk ones woudl b a good start?
phil
G
Generally the cases are very nice to work with - however the installation of the PA160 could have been easier.
phil
The fan-o-matic Pro was overkill in a machine of this size/spec, plus the model I have here needs RMA'ing as there is a fault with it.
I will be selling this little system in due course, and will of course stick the obligatory EP-UK grills on it :D
unreal said:
So thats 2x 120mm blowholes in top?
Whats the spec of water setup?
They are for separate 120 fans or another rad. But in my situation just for show :)
PA160
shroud
Vantec Stealth 120
Tygon 7/16
C-Systems Mag pump
Swifty Storm G4 (original)
NV78
Externally mounted 6" tuberes
