Memory Recommendation for X570
dipzy
Active member
Hi guys,
I'm going ITX (well DTX in my case) and just recently picked up a 3900x and a Crosshair VIII Impact.
What memory would you recommend?
I've read that 3600Mhz C16 B-Die kits are recommended.
32GB would be ideal.
So far I've found:
TEAM GROUP EDITION 32GB (2X16GB ) DDR4 PC4-28800C16 3600MHZ
I use G.Skill Trident Z Neo in that board. No experience with Team Group products.
Link for reference:
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232860?Item=N82E16820232860
Any 3600 C16 B-Die kit should be good as long as it's on the board's compatibility list. More than that usually work, but I'd play it safe.
Thank you, I'll check em out. Not many 3600 C16 kits on the boards QVL
My 3200 C14 kit is 8GB modules otherwise I'd of stuck them in.
I'm running a 2x16GB kit of TridentZ Neo, 3600 16-16-16-36 (EDIT: same kit posted above). No complaints, but you do pay extra for the tighter timings.
Looks to be a rare kit, I'd be happy to pay the little extra but can't find any in the UK.
2x16GB kit of TridentZ Neo, 3600 16-16-16-36 - just seen it arrive in-stock on Newegg which also ship to UK but just wondering that warranty will be an issue as will be customs :(
For £257, It's the cheapest I could find.
