FragTek
Review: Lian Li PC-75 Full Tower Case
I'll be reviewing the Lian Li PC-75 full tower case.
Specs
Case Type: Full Tower
Material: 1.2~2 mm aluminum with burshed anodized finishing
Drive Bays: 5.25" x 6/0, 3.5" x 3/6 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB2.0
Cooling System: 2 x 80mm front fans, 2 x 80mm rear fans
Motherboard Compatibility: EXT ATX & Pentium 4 (MAX SIZE: 12" x 13")
Dimensions: 23.5" x 8.3" x 23.2"(HxWxD)
Features: Horizontal converter kit for hidden HDD
Price: $195
Style:
This case is all about elegance and professionalism. No gawdy led's or funky "space age" look which makes it the cleanest looking case on the market. The huge side windoes is a huge plus if you have some equipment inside that you're dieing to show off. In my case, it was the only case that could both house all of my equipment and show it all off equally well. The aluminum is flawless and all of the edges / facades are beautiful. Lian Li gets a huge A+ for design on this baby.
Engineering:
This case is designed to the highest standards of any case manufacture to date. All of the pieces are quality manufactured with no flaws anywhere. The case fits together like a glove and all measurements / assembly at the factory is dead on. High grade ultra light aluminum make this case both breathtaking and light. The inside of the case is a work of art with only a few simple drawbacks. The first thing that takes away from this case just a bit is the lack of removable mobo tray, the second is the use of "stationary" drive bays (unlick the Antec / Chieftech design with the removable devide rails). The motherboard tray sits just far enough away from the right side of the case to allow for any wiring or CCFL boxes to be hidden, huge benefit for all of us that have tons of wiring running throughout our cases. Case fan placement is perfect as usual allowing for a good flow of air throughout. Removable hard drive bay is PERFECT for mounting a pair of Laing D4 water pumps, I couldn't have designed it better myself Amazing worksmanship throughout the entire case.
Pros:
- Light weight aluminum
- Gorgeous styling
- More room than you even know what to do with
- Top notch engineering
- Available in both silver and black
Cons:
- Price
- No removable mobo tray
Conclusion:
By far one of the very finest full tower cases on the market, I wouldn't hesitate one second spending $195 to pick up another one. You won't be dissapointed!
Specs
Expansion Slots: 7
Price: $195
Style:
Engineering:
Pros:
- Gorgeous styling
Cons:
- Price
Conclusion:
