Deadfire19
I have heard about plasticizer issues with this coolant. Could someone who has used/encountered this coolant before tell me if they have had any issues with it.
Thanks
Thanks
Masterkleer and XSPC hose is fine.
The plasticiser comes out of certain hoses when it reacts with the coolant.
Im using Mayhems & Masterkleer in Orca![]()
Yeah they said they had issues with Clearflex 60 and MasterKleer. Which are listed as two of the brands that work on the mayhems website.The coolant does have issues with certain hose..... Tygon and Primochill are the main ones.
Which Tygon has issues? mine seems ok?
Sorry for the necro but its relevant.
I just saw what happened to your Pastel coolant in orca. I have already bought the pastel coolant but would you still say its safe to use in my system. I may just use distilled water anyway after hearing what happened.
The "representative" of Mayhems did not sound very caring in the comments under your post.
What tubing do you have?
If the answer is not: "magical tubing from space"
I would get rid of the pastel like I did last night.
Or you can get similarly coloured tubing so that the pastel looks good in a tube res or w/e (that is assuming it stays the right colour, which mine did)
Wait so you got rid of you pastel coolant even though it stayed the same colour. I am worried about plasticizer issues mostly. But the support from mayhems seems terrible and now that TTLs pastel coolant has gone down the drain I am worried about putting it in my system and then having to spend a weekend draining, pulling waterblocks apart, cleaning and re-filling.
