Hi,
I am doing a new build but I want to keep it small due to lack of space in the room the pc will be situated.
I expect to use the following components: -
EVGA GTX 980 ACX 2.0
Asus Maximus VII Gene
i7 4790K
Teamgroup Vulcan Red 16GB 2400MHz
EVGA Supernova GS 650w PSU
Corsair Hydro H100i GTX
I initially thought I would use a Corsair Carbide 240 but I am going off the idea as it has no room for ODD and the side panel is so close to the gpu power connectors. The gpu quick release latch thingy doesn't appeal to me either.
I am not particularly fussed about it having a window either.
Any ideas would be much appreciated, thanks
Cases that interest me are: -
Fractal Design Node 804 - The problem I foresee is the slimline odd appears to be only accessible from the right side of the case therefore if the case is up against a wall you'll have to move the case all the time to put a disc in.
i7 4790K
