Major Internet Problems HELP PLEASE!
Excalabur50
Well-known member
Hey all getting some major errors trying to open web pages tried using three different browser too, no matter what I do I can't open YouTube in Chrome it just says establishing secure connection but wont open, in IE it just does nothing and in Firefox it gets SSL errors Eg. ssl_error_inappropriate fallback alert or something about handshake other webpages also wont open it took a few goes to get this open.
Have stopped my antivirus no difference have ran virus scan nothing found, ran a Malwarebytes scan nothing found
Try and open webpages and get waiting for Google-analytics.com or it just sits there saying trying to establish secure connection and then nothing happens
Ran ipconfig disconnect and reconnect no difference restarted PC no difference restarted Modem no difference
Anyone got any ideas or can help PLEASE!!!
Have you tried contacting your ISP, I believe most in AU offer 24/7 tech support. They usually arent very helpful, however it could be a line fault or an issue with the exchange or something.
Uninstalled firefox and chrome yet when i reboot in task manager it has google chrome installer 32bit as well as google crash handler and google crash handler 32bit running but i uninstalled and deleted the folder so buggered if i know what's going on and rebooted twice second time the installer waz missing but the other two were still there
  1. Have you tried using a different Computer and / or mobile device eg tablet or phone?
  2. Have you cleared cache on browsers?
  3. Have you updated flash player?
  4. Have you restarted router?
  5. Can you ping / tracert the site(s) in question?
That is the first things that spring to mind for this, if none of the above work, then I will have a think on more things that can cause it.
Well it has righted it's self so far, I left it uninstalled and switched off but before I uninstalled I deactivated adblock and changed my gmail password and when I reinstalled this morning things seem to be working. Not put Firefox back on but Chrome and so far web pages are opening even YouTube so I think it maybe an adblock issue.
YouWhat last night I did clear the cache,Flash was up to date, the router was restarted multiple times and I could not ping Google for love nor money
Damn well basics covered, but by sounds of what you have said, it either AdBlock or DNS issue ISP side (They will always say it not them even if it is for something like this as they usually have several DNS servers so sounds like the local one to you fell off map temp. ).
***edit***
Glad it all sorted for you now though :)
***edit***
Im glad it's all sorted for now too and since I've not put adblock plus back on web pages are opening much faster now which is great and thanks to all who responded to this problem :D
