Mach II ST little problem... I want a Mach II GT Control Board !!!
PicaXuu
Hi everybody !
It's my first post here !
Glad to be here !
I have bought a Mach II ST and a friend of mine has modded it for me with r404a...
The unit is working without any problems but...
When I turn off the PC, the unit doesn't turn off, it begins to turn on, turn off, turn on, turn off, etc...
Only removing the power cable will turn it off completely...
I know it's not good for the compressor so I want to eliminate this problem as soon as possible...
I think it's obviously a problem with the Control Board and I want to buy a Mach II GT Control Board, which is exactly the same as my Mach II ST one but with the LCD and USB working !!!
I would like to know if I can do that that way ?
Is it as simples as that ?
I can without any problems put the Mach II GT Control Board in ?
Thanks for your reply...
Also waiting for Extreme Prometeia Team email reply to my question in order to buy here the new Control Board...
Big phil will be around tomorrow to reply to you email mate .
anyways have u tried hooking the usb up yet on some of the early models the usb and lcd worked afaik ,then u can flash the firware wich might fix the problem but it does sound like a borked controller board
Phil does do controler boards and you can change them over
I got a new controller board to fix my f'ed up ST from phil and flashed it with the GT firmware and it works great. Added 3ft of cap tube and regassed with 404a.
