I have got an MACH 2 ST.
I have been having loads problems with it and I am about to RMA it.
The problem is if I did do that, the place I bought it from will not be able to give another as they don't stock it anymore. (Do you see the luvvvvv for mach-ness
The only thing I am unable to do is to flash the board. (Which might fix it)
But the damm usb connection on the ST doesn't work.
So I got 2 question>
-Is there any way to flash the damm MACH ST board?
-If I was to get the mach 2 pcb board is there a good chance my current problems will go away?
