Warlord Shigs
lo, im plannin on buyin a machII from phil and was wonderin if i ave 2 upgrade my psu aswell???
			Phil Stanbridge said:Guys, In my honest opinion I would use the most powerful psu you can find to power your Mach II.
This is the official blurb from nVENTIV:
Question: Which power supplies can be used with Mach II unit?
Answer: The Mach II Cooling System does not impose any extraordinary or abnormal load conditions for your PSU. Your only reason for exchanging the PSU would be your desire for a more extreme Overclocking. The compressor is driven directly from your Mains supply (115/230V).
At the end of the day you are wanting to achieve the best overclock possible so why limit that with a crappy psu. I have had confirmation back from the states that my PC Power & Cooling 510 Turbo Deluxe's are nearing ready for me. These are the best power supplies money can buy and although they are expensive at just under £200 each, they will not limit you in any shape or form. I certainly will be upgrading.
name='Phil Stanbridge' said:You can still get silent psu's mate at 520-550w.
name='Phil Stanbridge' said:Your Corsair 3700 can run dividers ok, the blue screen or crashes generally is probably related to something else, either lack of vcore or tight memory timings. The 4400 will be fine, but take into account the timings on those modules will be a lot slacker than the 3700.
name='aXeR' said:phil posted a source to buy the SL6WK for £160+carriage, i just found out thats why i have too, just need to get the vcore to be stable now for overclocking![]()
name='Warlord Shigs' said:do u mind postin the link again? was it from OcUk?
